Engine noise!!
  • Engine noise!!
    Just wondering if anyone has noticed d4d get noiser after a few k's on the clock (1890km) ? Might be just me but seems to be noiser now. Sounds more like a rodeo diesel then before.Mine is a manual 6spd. :shock:
    Cheers Phil.
    [size=1][b][i]07 D4D GXL PRADO 6spd man.[/i][/b][/size]
    [size=7][color=blue][i]BFG AT tyres 265/70/17,55mm ATS suspension,tow safe tow bar,Mine Trans seat covers,sandgrabba mats, 60 Litre Engel fridge,front tint,safari snorkle,arb deluxe bull bar, Hella HID lights,760cca dual battery setup,uniden uhf cb, and more to come !![/i][/color][/size]
    Not me, and I've done over 5,000km. Do you mean inside or outside? I still can't get over how quiet it is inside compared with the outside!
      Re: Engine noise!!
      Cheers Phil.
      Phil,
      If this means anything I have noticed the same condition but only when cold, Was informed be my dealer that they have had a few people with the same complaint. They contacted Toyota Technical dept & have since received a bulletin explaining that it was normal as the injection system double injects, or if you like runs richer when cold, but should quieten down when warm.
      (Believe it or not?)
      :?: Fazza
      07 D4D GXL Auto (4500 km)
      07 Silver Ash, GXL, D4D, Auto. Lifestyle rear cargo rack. 2500 kg Tow bar with Tekonsha elec brake controller, Rear dust deflector, Mio Sat nav, (Still trying to fault the Dunlop AT20's)
        Maybe i'm driving it a little harder then before, I know what you mean by being louder when cold just has that diesel noise coming through when say 1/4 throttle under load.
        Also have ratttle above drivers head somewhere at 90kph, might be something loose on roof rail mounts seeing i can hear it only at speed.
        Have to bring it in for warranty, hate rattles :twisted:
        Cheers Phil.
          Originally posted by Pradogxlv6
          Boys,
          make the engine work harder when first started to actually make them warm up faster..
          Matt
          Matt,
          Thank you for your input as it does back up the dealers statement.
          They also made the comment about making the engine work harder by injecting early, so as you commented the engine will warm up quicker.
          Cheers Fazza.
