Toyota is not happy with my exhaust
    Re: Toyota is not happy with my exhaust
    I appreciate your info nitrous.After your info i may have some recourse if it happens outside my warranty on our way around oz.
      Had the exact same issue occur to me 3/4 of the way to Canberra from Sydney. Engine light went on, car seemed to be in limp mode (the turbo wasnt working). Stopped on the side of the road, turned the car off, turned it back on and it was back to normal, however, the engine light was still on. Took it back to Toyota who mentioned that it was a clogged wastegate and that if it happened again they would replace the turbo.
      No mods to exhaust or engine ECU.
      2014 Toyota Prado 150 D4D Auto (facelift); ARB Deluxe Bullbar; OME 2" Lift; Rhino Pioneer Platform Rack; Redarc BCDC 1225 with Optima Yellow Top; BF Goodrich Mud Terrain KM2; Lightforce Genuine Custom 70w HID; GME UHF; Safari Snorkel; Rigid Industry SR-Q2 side lights (yet to be installed); Domin8or winch (yet to be installed)
        Just had mine for 20,000 (30,000) serivce...nothing said about the exhaust being modified. Does not get driven enought for the 20,000 serivce... :shock: Well the wife took it in.
        Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
          Update on my hiace guys.
          Mine had died again.
          Same thing.
          All power dropped and this time I waited for 30 minutes and started up and fine.
          Check engine light stayed on for about 3 hours then off by itself.
          Went back to Toyota today and they went over it again and they have ordered a new turbo and it will be installed soon.
          The van is out of warranty by a few weeks now but as I had the 1st problem within warranty they are doing all for free as I would expect.
          My mates van has done exactly the same a month ago.
          The dealer said they will clear the codes and reset a few times yet and see what happens....
          My mate asked what will happen if gets out of warranty?
          Dealer said will cross that bridge when it comes..... :roll:
            Puts my mind at ease as I had this problem occur once before and Toyota managed to fix it without replacing the turbo. In saying that you wouldn't by any chance know the error code for this problem?
              Yes I know the error code off by heart now lol
              P1251- stepper motor for turbo -intermittent.
              This is on a Hiace of course so not sure if same code for Prados etc.
              When you said toyota fixed it without replacing the turbo, all they do is let it rest for 30 minutes and delete the fault code as it rights itself.
              They wouldn't have done anything I am assuming.
              They have to replace the whole turbo as it's all intergrated.
              Stepper motor or I would call it boost controller is inbuilt in the turbo so have to do the works.
                Hoping a final update on this guys!
                Had the turbo replaced yesterday.
                As I dropped it off, there was another guy picking his hiace up after getting his turbo replaced!
                His is a 2008 model, mine is a 2007.
                They did 1 the week before also..
                My mates who has the same problem is a 2008.
                Toyota tells me the turbo has been revised after the problems so this is the newer version and "should" be fine from now on...
                Hope this helps any Prado and hilux owners out there!
