Prado power loss after turbo replacement
  • Prado power loss after turbo replacement
    Hi guys, I am at my wits end. The partners turbo gave up the ghost and we have since replaced it. Massive noise gone but now new issues have shown up. EGR vacuum solenoid was the culprit so I replaced it today. I took it for a drive and it seemed to be going fine, really good actually, when all of a sudden it lost boost and started blowing a lot of smoke. It felt like I was driving a NA diesel.
    No codes to report, no CEL on the dash so I am at a complete loss as to the issue now.
    Any ideas?
    I’m not sure about the problem myself, but I’m interested to know. If you disconnected the battery for a bit. Hold brake pedal down (discharge and stored power ). Then reconnected the battery. If this would help
    im assuming you checked all hoses for splitting
    11/06 kdj120 gx wide body auto
      Map sensor not blown off?
        MAP sensor has its vac hose, and I've checked all of the hoses for integrity and can't seem to find anything split.
        If anyone has a Prado in the area I can try a MAP sensor swap would be appreciated
          which are are you in?
            Redbank Plains is the car but I'm in Woolloongabba.
