See more
See less
1kz oil filter change question
  • 1kz oil filter change question
    Hey crew, I changed my oil and filter on the weekend, Just wondering does the oil filter drain pan actually catch the oil when you under the filter? made and awful mess , and no oil came out of the drain hose near the sump bolt ?
    That should say un do the filter
      Sounds like the drain hose is blocked.
        As the filter sits downward facing, most of the oil drains when the car is stopped the Filter pan, is there just to help with that small amount that may remain. I get a very small amount of oil out of mine... if anything.... but perhaps the drain hose is blocked??
