Hi Folks,
(Sorry this is so long, but I'm logging it for me too)
I'm seriously hoping that someone may have an idea of what is going on as we're at the end of our rope here.
We have a 120 D4D. It has almost 270ks on the clock. It's been serviced to the log book and beyond like clockwork. This is a really well looked after vehicle. Most of those ks are highway ks too.
Around January last year, I was driving home from work when I lost power after driving on the expressway for about an hour. I was parked at the lights and the car just would not go over 20 no matter how hard I pushed the accelerator. I put the hazard lights on, and started to pull over when WHAM! Off it went. I continued on for a while, dropped my son off at school and then it just completely turned off going down a hill. I have a scan tool and no errors were being thrown. I waited a few minutes and started it again and there was no issue. Everything looked fine.
I drove over the mechanic who had no idea. His scan tool showed nothing. So I went home.
Fast forward a month, and it did it again. Three times. Again no error code, and the car started just fine after doing it. Again, mechanic couldn't tell what it was. We started to suspect EGR issues, so I ran a treatment of Fuel Doctor for a while, and that seemed to fix it up. For the next 3 months it was perfect.
Then we went on holidays towing our camper. We went from Newcastle to Mildura without a problem. Spent a week driving around there without a problem. The day we were due to leave to head up to Broken Hill it did it. We had no option but to push on. It did it again crossing flood water at Menindee Lakes just out of Broken Hill. And then it was fine while we were there until the day we left. My wife was driving on the hwy and and went to overtake a road train. She got about 100m in front of it and it went properly into limp mode. This time the engine fault light came on and we absolutely packed our dacks. This must have been the only section of highway that we could pull over on which didn't have an embankment. Pulling over, I check the error - P2006 (https://www.autocodes.com/p2006_toyota.html).
The error seemed non critical, and the engine started OK, but still kept the engine fault light on. We decided to push on. The car would stall when going up pretty much every hill (we worked out after the 10th time that if we drove in 4th the problem wouldn't happen). We got home after 12 dreadful hours.
It went into the mechanic again the next day. Again, nothing found. Cleared the codes and we decided to look at getting the EGR done, the intake cleaned and whatever.
After a discussion with my dad, he knew someone at Toyota who was happy to take a look. The mechanic wasn't able to look until after Christmas, so being able to get it done in late November was appealing. Toyota took off the intake manifold and sent it off for cleaning. It was so clogged it needed two rounds of cleaning. The EGR was also cleaned. And they found a vacuum pump wasn't working, so that was replaced too.
When we got it back, it was fantastic. Drove pretty much like new. For about 2 weeks. Then as I drove, I could feel the car kind of 'spluttering'. Like a petrol car with a dirty carb or spark plugs. It was only noticable I guess cause I was waiting for it. Then last week, it started again. No power on take off after driving at a speed over 100 for a while. I pulled out into traffic with plenty of room to spare and it cut out causing quite a lot of angst as we almost got rear ended.
We've done the following:
Replaced front and rear fuel filter
New fuel pump
New air cleaners
New vacuum pump
Clean of EGR
Clean of intake manifold
I can't remember what else we've done, but it's costing us a fortune. I am hoping someone may have clues as what else we could be looking at. The only thing really left I think are the injectors. But not really convinced that they are the problem either.
Thanks for anything you can add.
Stuart.
New fuel pump
New air cleaners
New vacuum pump
Clean of EGR
Stuart.
