KDJ120 Diesel oil leak - what's this seal?
  • KDJ120 Diesel oil leak - what's this seal?
    Hi All, have a leak on passenger side of engine under the starter motor, see photos.. any ides what it's called? Hoping to replace leaking seal myself..
    Quick look on the parts catalogue its called Plug Hole P/No 1144467020 and has an O Ring Seal P/No 96721-24014 (or substitute 96743-24014) behind it so that is all you may need.
      Thanks heaps
      ptommo59
      ptommo59 part numbers worked a treat,.easy ordered via Toyota.. problem solved.. Much appreciated
        Just had the same oil leak on my 2008 D4D. I think all older Prados will get it too. The plug hole was $10 part #11444-67020 doesn't come with the O-ring or bolt. You probably just need the O-ring part #96743-24014 was $2. Old O-ring wasn't broke but it was flattened enough to leak. Multi-grips were good to pull to plug off as it will be greasy and a bit tight. Smear some oil on the new O-ring before pushing it back in. Bolt is 10 mm. Click image for larger version  Name:	Picture2.jpg Views:	0 Size:	8.5 KB ID:	769240
        campbell
        2008 D4D GXL
