Hi all,
Recently changed the diesel fuel filter for the first time myself after reading all the posts here I could find. Everything went to plan until I tried to prime the new filter. I kept pumping long enough to suspect something was wrong (at least 100 times). I disassembled and tested the pump on its own by dipping the inlet in diesel and it pumped the fuel without any problem.
Thinking maybe I had too much air in the fuel inlet line for the pump to create enough suction, I grabbed a small funnel and began pouring diesel in the fuel line to fill the line. Well I kept pouring and pouring, then pouring at a faster rate. It would get close to being full when pouring at a fast rate but the fluid would just drain down the line when I backed off pouring. I am pretty sure I poured between 1 and 2 liters down the fuel line. I checked under the vehicle and no leaks anywhere. Go figure?
I am puzzled and really hope someone with a lot more experience can shed some light on what happened. Is there a check valve (non return valve) in this line?
2006 KZJ120 with 197k on the clock
