well my dump pipe arrive today from advance headers in SA, part number is TT30 looks good for the money, it hasnt got an egt fitting but thats easy fixed, cost $320, outlet is 65mm so it is off to get fitted on monday, damonats gets fitted tuesday. should go a bit better then the std pipe :wink: . here are a few photos. cheers samo
Advance Headers 1kz dump pipe
Re: Advance Headers 1kz dump pipe
well had dump pipe installed with 3 inch muffler and used the std tail pipe and im very happy with the improvement in performance, spools up a lot quicker, makes full boost (12psi) as low as 1700rpm, the dead spot from 2500rpm up has gone, it happy winds out over 3000 plus rpm and not its loud at all, you definately know it has a system on it now but its not annoying, and turbo whistles like a happy canary. Over all im happy as, better performance a nice note to go with it. cheers samo
bb its well worth doing, i would have liked to just change the muffler and pipe then get the dump pipe installed a little later to see how much difference both would make, but it didnt make sense to have it at the shop 2 times and cost me twice, as i said before over all im very happy with the way if goes and sounds, if it gets annoying i can always throw a hotdog on the rear tail pipe and take the bark out of it. cheers samo.had an 03 gx 120 with some gear now got a 2013 bt 50 GT auto some ARB gear.
Interesting. I have been looking at a 3" system but the cost has put me off plus the likelihood that the extra noise will annoy A few questions if I may. Is the dump pipe stainless or mild steel? How much was the 3" muffler on top of the $320 for the dump pipe and is it ss or mild and does it have a 3" inlet and a 2 1/4" outlet to match the standard tailpipe? Lastly,is there any drumming noise or is it just a bit more throaty?
Cheers......WayneWhite 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
hublyw the dump pipe and the system is all mild steel, the price was very good, cant say as was a special price because family friend owns the shop, the muffler has a 3 inch inlet and a 2.5 inch outlet (factory pipe is 2.5 inch)where the std tail pipe is welded on, it has a nice throaty sound, well thats my opinion anyway, i will add a sound clip when i have a chance and people can decide if they like the note or not. cheers samohad an 03 gx 120 with some gear now got a 2013 bt 50 GT auto some ARB gear.
