PLEASE HELP DESPERATE ENGINE STUFF UP- now fixed thanks
    Re: PLEASE HELP DESPERATE ENGINE STUFF UP
    Hi Jaywindy. What a cockup! Might as well drain the oil and remove small inspection plate on sump. Get in there and have a good grope around or make up a scoop tool out of wire to help. At end of day you are going to have to find it somehow - no point in putting the dirty job off. Most garages have endoscopes now as they are really cheap and useful. If you cant get it yourself, get a mechanic to come over and have a fish around with his flash tool. Cheers, Derb.
    2005 100 Series Landcruiser. 4.2 T/D 5 speed auto. LTD c/w AHC/Leather etc.
      Hi
      Here is a 1kz engine with the rocker off. I take it it went down one of the holes on the drivers side?
      1kz engine by tassie tiger2010, on Flickr
      And here is the block with the head off and shows the big hole that it would have fell down
      1kz block 2 by tassie tiger2010, on Flickr
      Here is the bottom end showing what it fell past;
      url=http://www.flickr.com/photos/51699108@N05/5157081721/][/url]
      1kz crank by tassie tiger2010, on Flickr
      As you can see there is not much in there for it get stuck or jam up.
        Re: PLEASE HELP DESPERATE ENGINE STUFF UP- now fixed thanks
        Wow- thanks for the photos tassie tiger, Yes those small 40mm holes is where it went down.
        I have just come in from working on it all night, i removed the small tin sump and hoped the gauge would be there, and it wasnt. I looked around in the exposed engine and couldnt see it, I got out and as i tilted the small sump a outline of a oil soaked feeler gauge emerged in the bottom of the small sump. I kept looking at it for a few seconds - i couldnt believe i had that pesky gauge back.
        So great news and thanks to everyone that helped. I certainly learned a valuable lesson the hard way, I will be covering up all holes if i ever do this again!
        I had trouble uploading a couple of pictures direct so they can be see here:
        http://jaywindy.webs.com/apps/photos/al ... d=10340890
        Thanks jeff
          Woot! I can hear the hurrahs all the way from Adelaide :lol:
            Fantastic news!
            What do you think the point of the small sump pan is? What can you access engine wise once its removed, other than lost feeler gauges? :shock:
              Wow, well done. What a save!!
                Originally posted by tassie tiger
                Fantastic news!
                Hi Tassie Tiger,
                Speaking as a novice mechanic, it appears to function as a small well of deep oil where the strainer sits that sucks up the oil . I suppose it is also a removable section that allows you to clean out any sludge that could accumulate at the lowest point.
                I was suprised that on mine it was pefectly clean inside- like brand new just a film of clean oil. (105000km).
                BTW. It is also is a retrieval method for lost feeler gauges, I wonder why it doesnt mention that in the toyota manual??? :wink:
                Just filled the oil back up tonite and re-installed the rocker cover, waiting for replacement Glow plugs to arrive b4 i can get it finished.
                Regards
                jeff
                  I am glad u found the solution without having to pull more to bits
                  David
                  ...If its not on all 4's it's not on.....
                  2008 GXL D4D, OME lift, arb bar, IPF 55W HIDs, HID headlights, duel Batteries, Winch, UHF, Safari Snorkel, bfg km2's, arb side awning, rola cage, engel fridge, kaymar rear bar(to fit)
