Mine stall when backing off with steering wheel in full right or left position, needs some expert opinions and remedy
2008 D4D stalls Intermittently
Whitey, my Nov-2007 D4D had the same symptoms. I bought the car used at 160,000km and immediately replaced all four injectors,seats,seals etc so impossible to say if new injectors made any difference. Freo Fuel Injectors in Perth reported seeing one other D4D Prado that intermittently stalled on a warm engine - they apparently spent considerable time searching for the problem through process of elimination (sorry, I didn't write down what they'd looked at) but in the end replaced the fuel pump which fixed the problem. I decided to get the fuel pump replaced in the first instance and likewise have not experienced any further stalling over 5000km travelled. I also had an extra fuel filter installed under the bonnet when the injectors were swapped.
I hope this info helps!11/2007 Prado GXL D4D Auto [B]BLACK [/B]Stock Option 1.
Wasim if your injector sheets were leaking then I would suggest dropping the sump and cleaning the oil pick up screen, at least drop the oil and inspect it. When the sheets leak they cook the engine oil near the leak which goes gluey and will eventually fall back into the sump. When it get sucked onto the screen these lumps cannot pass and build up and can starve the engine of oil.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
Wasim,
Check this link to learn more about what MJRandom is talking about. Quite a serious issue for this car...
http://www.baileysdiesel.com/on-high...l-sump-pickup/
