Hi All,
Firstly I'd like to say that the problem happens on Petrol and LPG so we can rule out fuel.
it starts and idles fine with a slight miss now and then.
But when I press the accelerator it coughs for a bit and then catches on and goes but not great like it used to. The problem started a while a go and has slowly gotten worse.
no lights coming up on the dash and nothing specific coming up in techstream when I plug in the computer that I can see or understand.
I can hear the throttle opening through the snorkel sucking air. I think what may be happening is it is not supplying the correct injections to the air and therefore may be the air flow meter might not be supplying the correct current? I have just changed all plugs and all new genuine ignition coils.
your thoughts please?
