hi there guys
I have an 05 v6 prado that has the engine light coming on intermittently
I have had it on the scanner and it come up with
P0504 - Brake switch electrical circuit interrelationship
p0571 - Cruise control brake circuit
after a bit of research i found that these codes are related to the brake switch that I have since replaced the brake switch
now the light still coming on with no codes showing on the scanner .
the engine light comes on after when i use the central and that fails to unlock the car ( indicator only flashes once and very fast ) I then repress the remote and it unlocks when i start the car the eng light is on and remains on for any period of time
Now when the light decides to go off the car dies looses power but doesnt stall for aprox 3-5 seconds ( like it is going into limp mode )
any ideas as to what it could be would be greatly appreciated
Thanks in advance
Heljas
Thanks in advance
Heljas
