G'day,
Just took the front bash plate off to check the bottom of the motor over. Found oil leaks from around the front of the motor, pretty sure its the sump gasket.
Anyone out there ever had to replace one? If so, what did it set you back and was it a pita??
Thanks a heap :wink:
