Hi,
Some advise for a newbie?
Just returned from a trip in 120 petrol (auto). When in neutral the vehicle revs fine . When in gear (drive of other) the engine experiences power loss. Can't accellarate etc. Revs are all over the place :cry: . Simptoms are similar to water in petrol or crook air flow meter. (Cruise control has no impact).
I had to pull over switch off and restart which teporarily improved the symptoms to get home.
The MAF was replaced earlier this year. (May check it again and clean. Is Isopropyl Alcohol the preferred cleaner? :?: )
Is there a sensor on the gearbox or other that can cause this.
This only happens in gear - no prob in P of N.
Gratefull for any advise...
TS
TS
