When replacing the air cleaner element on my V6, I noticed after removing the upstream boot and intake ducting which connects to the cavity between the engine bay and side panel, that there is a small plastic reservoir with a 1 way rubber valve on the underside of the intake. I'm not sure of the exact function of this device, (perhaps a drain valve for water?) but it was so crammed full of dirt, dust and debris that it was completely clogged. If your Prado has seen a bit of 4WD work it may be worth checking this next time you open the bonnet. Hope this helps others - I had no idea it was there!
While I'm on the subject, does anyone now the function of the fine mesh screen which sits between the air filter and the intake manifold? If it is a filtration device one would think it should sit upstream of the air filter element to remove larger particles. :?
