what to do first when servicing/checking 2nd hand 120
  • what to do first when servicing/checking 2nd hand 120
    Hi,
    I just purchased a 2nd hand ex mine 120 3l Auto 2004 with 284,000 on the clock (the price was right for me :wink
    I have spent time looking through PP and can see plenty how to do's etc. But am struggling on what sort of maintenance should be done "first" and what to look out for.
    I am planning to give it a decent once over, change all the filters, take trim off to get as much of the red dust as possible off(got the CT18 all set to go).
    So accepting it's ex mines with high km's, I am keen to draw on the PP knowlegde bank to help point out some what are some of the things I need to look for (then I can go to the "how to"parts of this great forum) and what I should be doing first from a maitenance perspective
    It has a steel bull bar (no spotties) with electric cut off point/switch, side steps (not bent or dented), cargo barrier, internal roll bar, anti rust system. Rubber is std but new.
    I am planning to use the new rig to get to some of the better fishing spots as well as getting out to see more of this great country, not wanting to get into "hard core" stuff, just off the beaten track.
    Re: what to do first when servicing/checking 2nd hand 120
    I would do the major service:
    Change engine oil + filter
    Change fuel filter
    Change air filter and clean Mass Air Flow (MAF) sensor :arrow: viewtopic.php?f=14&t=3196&p=43237
    Complete brake flush and check brake pads :arrow: viewtopic.php?f=6&t=4234
    Change front diff, rear diff and transfer case oil :arrow: viewtopic.php?f=10&t=4537
    Change transmission oil :arrow: viewtopic.php?f=10&t=7732
    Grease CV joints and prop shaft :arrow: viewtopic.php?f=10&t=4663
    Remove the 2 bash plates at the front and then give it a good wash. :arrow: viewtopic.php?f=2&t=12288&start=0&st=0&sk=t&sd=a
    Check the rear door seal, lift it off and check for rust. :arrow: viewtopic.php?f=8&t=9487&start=0&st=0&sk=t&sd=a
    Check if rear door is sagging :arrow: http://pradopoint.com/viewtopic.php?t=569
      Being ex-mine, I would have a thorough search around underneath, chassis rails and suspension components for any rust.
      Even though you said it has the anti rust system.
      I saw a few in car yards just before they got detailed...
      More to come!
        Thanks for going to such effort linking the threads. There are a few things I havent done since getting mine and will check on the weekend
          That's a great checklist amts, and even better with the links, thanks for the hardwork putting it together.
          [b]Toddy...[/b] [size=1][b]2006 GXL Prado[/b] : Silver : ARB Sahara Bar : EFS Elite Suspension : PolyAirs : Airtec Snorkel : ABR HID Spotlights : AMTS Bashplates : DIY Water tank : DIY Rear Drawers : DIY Fold down Table : GME TX3440 : ARB Dual Battery System : DIY rear sockets : DIY Washer Jet Upgrade : Tekonsha P3 : DIY Rear Diff Breather : radopoint Sticker (no P): Pink MaxTrax (Yes) :
          [b]2010 Jimboomba Maddison Off Road CT[/b] : DIY 12V system : DIY Electric Water Pump :[/size]
            thanks heaps, that's great information, "amts" you have gone over and above, saved me heaps of time- thank you
            now it's time to roll up the sleeves and remove the "mines" mess
              No worries. I'll PM you all my bank details. :lol:
                Good info . Thanks.
                New KZJ120 Owner
                  Hi Fellas. A few "Add To's" for the list. Power steering fluid. Dismantle viscous fan hub and refill with new fluid. Replace all drive belts. Drain cooling system and replace thermostat and rust inhibitor. Check all hoses. Replace starter motor contacts. Alternator brushes and bearings. Your rear axle seals will also need checking for weeping ( do when checking brakes). Check diff breathers for blockages. It may seem an overkill but costs f_____ all and heads off prob's later. Cheers.
                  2005 100 Series Landcruiser. 4.2 T/D 5 speed auto. LTD c/w AHC/Leather etc.
                    got more to add to my list, Front right hand side is "clicking" in 4x4 L full lock.... CV's need to be replaced, noticed the inner CV boot on the left hand side has now lost it's steel ring so going to replace both sides.
                    I am planning to do this at home, is there anything I should be aware of? any "got ya" ops: I need to know about? don't have a maintenance manual yet, have ordered one from the interent :wink:
