I know there is a way to adjust how tightly doors are shut. At the moment they are not as tight whilst shut and therefore they rattle a bit
How do you tighten doors?
Hey Pj,
there's 2 possible reasons I can think of why they're not super tight.
One is that they are and your seals have had it... new seals required
Two is that either the door hook or the latch on which the hook grabs on to are worn and may need to be replaced with newer fatter ones. It could also be the spring that tells the hook to close more has had it and may need a new spring. Shouldn't be a hard job at all if you can get the parts and know how to use a spanner and some paint (to paint over the nuts again).
Hope this helps,
LozLoz - 2007 GXL D4D Auto White
ARB Deluxe Winch Bar, 2" OME Lift, ARB On-Board Air, Safari Snorkel, GME TX3440 UHF, GME AE4018K1 antenna, Redarc/Exide ED5 dual battery system, ARB 47L fridge, Cooper AT3's 265/70/17, LeighW's voltage booster, Lightforce 240XGT's, Outback Solutions Drawer Systems
[url=http://www.pradopoint.com/showthread.php?20863-Loz-s-120-GXL-D4D-Prado&highlight=loz%27s]My Rig Build-Up[/url]
