I have a 2003 V6 with a dodgey fuel guage. The needle is not moving off empty, however the green light still comes on for the second tank and the orange warning light comes on when almost empty.
Checked my manual and figured that the problem could be one of 4 things:
1. Fuse
2. Fuel guage tank sender unit on main tank
3. Fuel guage tank sender unit on secondary tank
4. The actual guage itself may be faulty
The easy check was the fuse which I have done and all is OK.
The next three are going to be a bit more difficult so I thought I would post here first to get any advice or ideas.
Has any one else had a similar problem.
Wasn't sure if I should post this under electrical, engine, or body, so I chose general.
Cheers - Byrnsie
1. Fuse
Cheers - Byrnsie
