Hi, I have a 08 GXL prado that i will have to mount a phone cradle into. Just after some ideas on were to mount it.
Cheers.
U can fit a bracket between the radio and the grey panel the runs around the vents, check my build up.
Hutch- 2007 V6 GXL.
2012 V6 GXL on order.
[b]Rob[/b]
Try www.holdmyphone.com.au as well, I have one and it looks very similar to these. The only thing I don't like about it is that it blocks some of the air flow from the vent, other than that it works really well.
Justin
2005 120 Series 3.0 TD Auto, OME suspension, Sovereign bullbar, IPF 900XS driving lights, Projecta dual battery system, ARB roof rack, Bridgestone D694 tyres, GME UHF, Custom rear drawer with ARB fridge slide and Waeco 60lt fridge.
I removed the passenger seat belt light on the dash and fitted a Ram mount into the hole. I can then mount phone, iPad or GPS depending on what I need.
Hmm its just the standard diamond shaped mount. I had to trim the edges of it a bit but it screws in just fine. I use different length arms depending on what it has to hold.
Model: RAM Mount Diamond Plate with 1 inch Ball RAM-B-238U
Part No: RAM-B-238U
Part No: RAM-B-238U
Part No: RAM-B-238U
Any Pictures? They say a thousand words.
Thanx
Alan
[color=#0000BF](The MK II) 2012 GXL Auto Diesel, White, ARB Bull Bar, Warn 9500lb XDC Winch, ARB Alloy Roof Rack, Aussieoutdoordirect Awning, Toyota Tow Bar, Safari Snorkel, ORS Rear Drawers and Fridge Slide, ARB Battery System with REDARC isolator, ERPS 10 Pad electronic Rust Cont, 275/65/17 BFG AT's, Jumbuck Sheep Skin Seat Covers, REDARC EBRH Brake Controller, OME 2" lift kit, Air Bag Man high pressure air bags, ARB CKMA12 on board compressor.[/color]
