2007 VX Cool Box Drain Blocked
  • 2007 VX Cool Box Drain Blocked
    Do the the Downunder 2007 VX's come equipped with the Cool Box between the front seats?
    Anyhow, mine has a drain in the forward RH corner which has become blocked - tried the usual with a piece of coated wire to try and clear it but there is an obstruction about 100mm/6" down. Slid underneath but can't see any obvious exit point to try and clear from that end.
    Anyone have any suggestions...?
    [color=#0000BF]2007 Prado VX 1KZ-TE Turbo Diesel
    Bilstein Shocks | King Coils | Hilux Washer Jets Upgrade | Xray Vision 200 QH | ARB Compressor | BFG 265 65 17 AT's[/color]
    [url=http://www.fuelly.com/driver/Bonno/prado][img]http://www.fuelly.com/smallsig-metric/47577.png[/img][/url]
    Mine was blocked up sometime ago and I blew it out with a compressor. work a charm...
      Thanks Craigm - it worked a treat - I always knew my ARB compressor would have more uses than just re-inflating my tires!
        There is a flap valve halfway down, if you remove the drivers seat and plastic cover you can see it. Its therte to stop dust coming back up the pipe
          Hello guys. I was wondering if its ok to wash down the cool box. Yes there is a fan, but atleast like rinse the drain and then clean it with compressed air. I have a little baby and his baby milk that was in the cool box during a long trip had spilled. I did clean it up with disinfectant wipes, but my cool box is beginning to smell. Any input will be greatly appreciated.
