Gday,
I have booked the Prado in for a new radiator core at my local 'Specialist' and I asked the question about the fans efficiency and if a Thermal fan would be worth installing.
The bloke advise me that a thermal was not necessary and that if any thing 'Repacking the Viscous Fan' would be sufficient.
Apparently 'Repacking' means refilling the visocous fan with the correct oil until full again...
Has any one done this? Did you 'Repack' or 'Replace' the fan hub?
Seeing how the car has 250K on the clock, I will be replacing the water pump whilst the radiator is out and in my mind this fan mod seems like a good idea...
Any feedback would be appreciated.
Cheers Drew.
Cheers Drew.
