High frequency vibration through steering wheel
  • High frequency vibration through steering wheel
    I have a 2008 120 diesel GX manual. Under hard acceleration the steering wheel starts to buzz, i.e. it has a high frequency vibration coming up the steering column.
    I have rebalanced the wheels, the wheel bearings are good as are all the bearings on the diff etc etc.
    I have had a look at the "backlash" on the front diff. The bolts on the input flange rotate approx 11mm, the rear diff rotates approx. 4mm. I have asked Toyota if the backlash on the front diff is a) normal and b) if not, would cause the vibration. No answer so far! Any thoughts?
    I have checked all the undertrays and they are secure.
    I have recently changed the front diff oil.
    I would appreciate any thoughts / similar experiences.
    tappets
    Do you run mud terrain tyres by any chance?
    2[FONT=Arial Narrow]008 Prado GXL D4D Auto with Prado Pack
    4x4 History: 2000 Prado GXL 90 Series 1KZ-TE, 1992 4runner 2.8 Motson turbo, 1985 Landcruiser 60 Series 3.9L Diesel, 1985 4Runner 2L 2.4 Diesel later mod. + 2.4T (Factory Turbo), 1982 Hilux 2.2L Diesel in Yellow (callsign 'Yellow Peril') later mod. + 2.4L engine[/FONT]
      Do you have a suspension lift?
        It has the original Dunlop tyres and std suspension.
          Hi tappets, did you manage to solve the steering wheel vibration ?
