1GR-FE Timing chain/tensioner/guides change interval (120 series)
  • 1GR-FE Timing chain/tensioner/guides change interval (120 series)
    Hello All
    I recently purchased a 120 series prado and i can not find anywhere if there is a interval to change the chain guides or tensioners,the only thing i have found on a forum was somebody said it should last the life of the engine/vehicle but considering its moving mechanical parts i am a bit sceptical and toyota dont seem to be of much assistance either.
    was wondering if anybody had any previous experiance with this?
    thanks .
    I have 4 Hilux cab chassis in my work fleet
    with the same engine as the Prado - 1GRFE one has recently had a 660,000k service performed and the others are all over 500,000k and none have even had a rocker cover removed. Don't worry about it as with regular servicing they seemed go for ever.
    Cheers Rick
    AussieTDM
      Couldn't find any information on this topic either mate, went into 3 toyota dealerships and got funny looks from all of them, "don't worry about it" was the catchcry of the day, took it to my mechanic, and at least another 10 different 4wd shops/mechanics and got the same response, apparently this and valve checks are almost non existent, unless oil is pissing out the sides of you're cover you simply leave it alone. Ive bought 2nd hand petrol with 200 000klms in the last 2 months and was compiling a list of preventative maintenance to do straight up so i now it,s all good, apparently change the oil and filter,s about it, dunno, keep us posted if you do find any info mate, would be appreciated.
      cheers
