Grande centre console chiller drain pipe issue
  • Grande centre console chiller drain pipe issue
    Hello all,
    Recently did a little bit of refurbishment of my centre chilled console on my 2005 Grande. The previously owner didnt look after it at all, bolts rusting out, tray going mouldy etc. I replaced the bolts and bought a new tray from toyota. And then whilst cleaning it I found it had a little drain hole for the moisture to disappear to. My drain hole appears to be blocked tried to poke some wipper snipper cable down there to dislodge but seems to just suddlenly stop about 10 - 15cms in.
    I thought someone else out there may have come across this and may have some ideas
    Troy
    2005 Toyota Prado Grande 3.0 TD - ARB Deluxe winch bar, Avenger 9500lb winch - nylon rope, Safari Snorkel, DP Diesel Chip, Lightforce HID 240's 50w, Oricom UHF, Bushranger Mud Tamer mats, Toyota Genuine Tow Bar, Toyota Genuine bonnet protector and headlight protectors, ARB Roof top tent and awning, ARB dual battery system with Red ARC and Optima deep cycle battery, Max Trax, ARB Compressor and Rear Air Locker, Waeco 50L fridge/freezer.
    See here
    http://www.pradopoint.com/showthread...l=1#post237773
      Blew mine out with a compressor Troy. Depends how compacted your blockage is but hopefully that should do it...
        Thanks Guys
