Hey all,
So the Mrs backed into a pole about 3 weeks after we bought the Prado, that was 2 years ago. I finally found a replacement part at a wrecker yesterday and figured while I;m waiting around for cyclone Ita I'll knock this 'little' job of the list.
Well I'm a bit stuck. Clearly most of the Plastic hood is held on with those little plastic push clip things but there is one actual screw. It is dual sided so one side goes into the prado door, the other screws into the plastic hood.
How the hell do I do that?
some pictures to try and help my explaination.
This is the hood lined up with the door:
This is the double sided screw, the smaller side goes into the door, the larger side sticks out to be screwed into the hood:
This is what it looks like in the door:
This is the threaded part on the hood:
So as you can see, the push in plastic clips and respective slots on the hood can all be attached and slide to the right to lock in, but by that stage there isn't room to be screwing in the bolt?
What am I missing here?
