Morning prado point members. I'm trying to find measurements from chrome grill to front of bullbars and also the approach angle of different bars. It seems the xrox has a good approach angle but I'd rather the three hoop so the lights are protected too. Is it possible to weld extra bits onto the bar maybe ?
Bullbar measurements.
Chrome grill to centre front on the ARB deluxe is 210mm, add 30mm where the rubber bump stops are.
ARB would have the approach angle, but just remember that measurement is not the be all and end all of things. I think from memory the ARB bar is similar or worse than the Sovereign bar, however the approach angle in front of the wheel is far better, so in practical terms a lot better off road.
Funny, it was only a few weeks ago I was discussing the idea of changing my ARB steel bar to an Xrox to save some weight. I decided against it as I travel frequently so hitting a roo is pretty much guaranteed, I already had a couple close calls in the past. Then it happened, 1 roo, 100km/h, managed to brake to around 80km/h, hit the bar with a thud. No issues apart from a cracked reflector. That's 2 cars and 1 roo in the past year and it's still going strong. Xrox bars might be great for comp vehicles but not a tourer.Originally posted by Piggy View PostI wouldn't be thinking an Xrox is going to give you any protection..
Saw one after a Roo hit the other day in WA.. Tow job..Last edited by glen_ep; 02-05-2014, 12:55 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
An xrox or similar comp bar provides very little protection if any under the bar. Have a look at the inner guard panels, totally exposed. Useless in my opinion and that is without commenting on how they look.My 150 build - http://www.pradopoint.com/showthread.php?27423-A-Random-approach-to-a-Bluestorm-150-GXL-D4D-automatic
