I had the aircon error light flash the other day. Is working fine now tho.
warranty issues - a list of faults?
Warranty Faults: That Clunk.
Roddy I have the same problem with Stewart Toyota, had the slip joint greased, only to have the clunk return. Do you experience the clunk when applying and releasing the footbrake ?. It happens more often than not. When I first bought this up with Stewart Toyotas Service Dept , I was told this happens when the brakes are released, and was normal, yet this clunk is intermittent. After several visits they still insist there is nothing wrong. I'm changing to another dealer, get another opinion.2006 TD Grande Auto Nudge Bar Reverse Camera Toyota Tow Bar Coopers
Re: Warranty Faults: That Clunk.
hi,
mine does it as i come to a stop. Let me know how you go with another dealer - and which one. I think i may try the same. I only use Stewart Toyota as they are my local dealer - never been real keen on them though. - in fact i'm not keen to use any dealer actually.. certainly not for servicing
cheers, Rod
Originally posted by robmalRoddy I have the same problem with Stewart Toyota, had the slip joint greased, only to have the clunk return. Do you experience the clunk when applying and releasing the footbrake ?. It happens more often than not. When I first bought this up with Stewart Toyotas Service Dept , I was told this happens when the brakes are released, and was normal, yet this clunk is intermittent. After several visits they still insist there is nothing wrong. I'm changing to another dealer, get another opinion.2005 VX V6 4.0L, Pearl White, Sovereign bar, nitestalker spotties, Tow Pack, Headlight & Bonnet Protectors, radiator bash plate, sandgrabba mats, cargo mat, DVD in headrest, radiator insect screen,
Guys, the driveline clunk is definately a replace part issue. I had it some time ago and was advised by Sci-Fleet Toyota in Brisbane that this had been identified in the Prado and the Hilux and a replacement driveshaft should be fitted to solve the issue. The replacement has a chamfered end the prevents the sticking issue.
Replaced under warranty with no issues.
Geoff...NOT LOST. EXPLORING!
04 GXL V6 Auto. ARB Deluxe Winch Bar, OME 2" Lift, Dual Batteries (Redarc), Warn XD9000 Winch, Safari Snorkel, Custom Drawers & Sliders, Rear ARB Air Locker, GME TX3200, Rhino Racks, Kaymar Rear Bar (with Jerry Can Holders & Spare Wheel), Polaris Awning, Waeco 35l & 50l Fridges, K&N Air Filter, Washer Upgrade, Firestone Air Bags, Trackabout Camper Trailer.
Geoff,
thanks - i will chase the issue.
cheers, Rod
Originally posted by GeoffOGuys, the driveline clunk is definately a replace part issue. I had it some time ago and was advised by Sci-Fleet Toyota in Brisbane that this had been identified in the Prado and the Hilux and a replacement driveshaft should be fitted to solve the issue. The replacement has a chamfered end the prevents the sticking issue.
Geoff...2005 VX V6 4.0L, Pearl White, Sovereign bar, nitestalker spotties, Tow Pack, Headlight & Bonnet Protectors, radiator bash plate, sandgrabba mats, cargo mat, DVD in headrest, radiator insect screen,
Originally posted by GeoffOGuys, the driveline clunk is definately a replace part issue. ...
40,000 kms and counting for me since the greasing and not one clunk.
Warranty issues
My 120 is now well out of warranty. Toyota replaced the serpentine belt idler at 60,000km because the bearing was noisy. The other fault dealt with under warranty was a sympathetic vibration at around 100kph, cured by installing a weight to change the resonant frequency of the front suspension.
A curious low thudding from the rear is fuel slopping around. Although Toyota offers a new tank to deal with this, the internal baffles probably rob capacity, so I didn't bother.]}:-{>
[b]2004 VX V6 120 4-speed auto[/b]
OME lift, safari snorkel, steel bumpers, ally bash plate and LightForce spotlights. Still working on it...
