Hi all ,it has been a while since i was here.....good to see lots of feedback and lots more posts.
i have a may 07 built 4.0 v6 petrol Auto Prado that has only 7000km on the clock and have had it since new.
My trouble(s) is this.
(1) I am having trouble with the gear selector switch sticking or not working properly,
It happens on the flat ground and on a driveway (with a slight hill) in park trying to go to reverse or drive.
With the engine on, push my foot on the brake and try to select reverse or drive,i must pump the brake 2-3 times then try again and then it releases the gear selector.
(2)This is my first auto 4x4 and i am not happy with they way the auto selects gears(and the time it takes),
Being a 5 speed auto i hear the trans go to 5th at about 55-60kmh (city driving),now when i want some power (to overtake) I am getting a very long delay(about 3-4 sec) for the trans to drop back.
(3)About 2 weeks ago i was 4wding and selected Low range when stopped and in park,with my foot on the brake i selected drive (after having same selector problem #1) and it jerks very harsh into gear.this problem is the same from neutral to reverse or drive.(also car engine was warm and not revving)
can someone please tell me these problems i am having are normal.
yesterday i took the car in for the 10,000km service(was due at January 2008) and told them about the 3 problems.
After 5 hrs service and checking problems they came back with the following answers:
Selector switch has no adjustment,tried many times no fault found.
Auto trans was checked for fault codes and no fault codes found nothing wrong with it................:?
Could not find a fault with item #3.......no fault found
I work in the car industry driving cars all day and i am wondering if i am comparing my car to other cars i drive and am i being to picky or has other people here had same problems?These problems all seem to be about the transmission area and i am thinking something is not working properly.
Thank you all in advance for your reply s.
Grid
Grid
