Do the charge of the battery go faster
  • Do the charge of the battery go faster
    Hello Everyone,
    I would like to ask if the charge of the battery go faster if DRLs are installed? and if i connect the DRLs with dim light is there any problem with it?
    Basically, NO
    Alternator will charge at the same rate with or without DRL, even spotties and accessories the alternator will still charge at same rate, you can get a diode to up the voltage a little bit more, most alternators will keep up ok
    [SIZE=5][I]​You take the highway..I'll take the by way[/I][/SIZE]
