Can anyone please tell me what a 2005 3.0 ltr diesel manual prado factory turbo boost is. I have heard about 16psi is this right
Factory turbo boost 2005 prado
Toyota service info says that pressure at 4600rpm (measured while in neutral and pedal flat to the floor) should be 7.4 to 9.7 psi. I'd post the Toyota info but its subject to copyright.
Snappa'06 RV 1KZ-TE, BFG AT's LT 265/70/17 (2nd set), Hilux washer jets, Bosch Aero Wipers, Nokia Bluetooth car kit, Safari Snorkel, 12v ARB Portable Compressor, Hi-lift jack & winch kit, Unifilter Reusable Airfilter, DP Chip, ProVent 200
Originally posted by Snappa View PostToyota service info says that pressure at 4600rpm (measured while in neutral and pedal flat to the floor) should be 7.4 to 9.7 psi. I'd post the Toyota info but its subject to copyright.
Snappa
1kd is 100kPa/14psi[SIZE=2]120 GXL D4D Auto, with a 'List of Wants' greater than the 'List of Needs' greater than the 'List of Haves'
