Climate Control Issues
  • Climate Control Issues
    Hey guys,
    I'm having some issues with my air con at the moment.
    I guess I should start by saying my rig is a 08 manual D4d with dual zone climate.
    When I turn on the cold, to say 22 degrees, the drivers side a/c works fine. Im getting cold air and no issues there, however the passenger side is blowing out warmer air, to the point where I think its actually just blowing the room temp air and im getting no conditioning.
    Ive tried raising and lowering the temps but still nothing.
    I should also say, Its definitely not because ive just left the passenger side set higher and I have no clue how to use duel zone lol
    I assume its not the refrigerant because im still getting cold a/c on the drivers side. It'd more likely be something wrong with the system.
    Any help would be appreciated.
    Simsy
    Sounds like the dual zone is playing up? Trip to Toyota or the mechanics maybe to get plugged in to see if anything has been left unplugged or is faulty?
      I don't have time about to walk out the door other wise I would search for you but keep doing a google search because some one else on here has had the exact same issue and they did post back with what the fix was. I cant remember if it was a sticking flap down under ?? but that is springing to mind.......When doing google search I always add pradopoint at the end it helps narrow it down....Cheers Steve
        I recall something like that too, sticky flap makes sense
