Hi, have a 2003 petrol GXL. Recently did a long trip from Sydney to Adelaide with 2-3 hour stints. Found that after a while the air conditioner became less effective and required more fan power to push air through. It also started to leak dops of cold water into the foot well. It appears that it was icing up. Turning it off for a period allowing it to defrost and it performed as normal for a while and then iced up again. Have not had this problem on shorter trips around town. Drain appears to function ok.
Any ideas? A sensor? Thermostat?
Ben
Ben
