I need to replace the front struts on my 2009 120 series Prado can someone advise how to do this?
front struts (Shockabsorbers)
Hey macca22,
It's pretty straightforward when you follow the procedure...here is a link to amts point by point procedure, which is on the last page of the link that Andrew showed you.
http://www.pradopoint.com/showthread...ade-for-Grande
No need for spring compressors, just need a good torque wrench.
Use a felt pen to mark your camber bolt positions before you push the lower control arms down.
Best
Whitey
