Help-Power window
  • Help-Power window
    Good day, I just recently replaced my dying battery. After installing new one, driver side power window controls are not working. I can't control all passenger windows only in driver side window. Do i have to reset the whole system? Any solution for this? Thanks
    Have you had a crack at searchin for it? :wink:
    2008 GXL M6 D4D, Silver
    Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
    [b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
    [img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
      Yep search its been covered 8)
        http://www.pradopoint.com/viewtopic.php?t=857
          http://www.pradopoint.com/viewtopic.php ... ht=windows
          All found with a search on "windows"
          Please also place your location in your profile.
            thanks fellas
              It Doesnt just happen with "dead" batteries or disconection of the battery.
              The other day I let one of my batteries run down too far.
              It did the old brrrrr brrr thing when I tried to start.
              I switched batteries, (which I can do with out losing power as my switch is "make before break")
              It started, so I switched back to charge the low one.
              Anyway, that was enough for the windows to need reseting.
              Jeff.
              W. C. Fields (1880 - 1946)
                Is there anything to remember before and after changing the battery like resetting window/dashboard if feel that my fuel gauge meter stuck in half and not activating the subtank warning light after changing the battery any clues? or im just being so skeptical. thanks
                  The only things that need to be done after a complete battery disconnection is the windows and clock and possibly radio settings if you have certain types of radio.
                  The fuel gauge and/or light should not be an issue.
                  But I will be corrected if im wrong.
                  Jeff.
