heads up if you have LPG
  • heads up if you have LPG
    Had a horror few days trying to figure out why safety lights came on my dash, after a few days I finally caught a wiff of smoke under the bonet and traced it to a brake fluid leak.
    so if you have gas fitted to your v6 check right at the back of your motor where the 2 hoses go from your gas system. And make sure the hose clamp is not rubbing against your brake lines.it took 6 years for it to rub through so now might be a good time for you all to check yours.
    Wowsers
