I was in the middle of the Gregory National Park last month when I discovered my Prado was leaking diesel from the forward fuel tank. There was a small .5 cm hole in the protective steel protecting the tank from below. It looked like a steel rod had somehow gone through the steel from the rear and punctured the tank inside, perhaps when I was reversing although the real cause is a mystery as it was too small for a star picket.
I made it to Kununurra where Toyota Broome did a good job and plastic welded up the actual tank( which apparently is plastic).
However I don't understand the actual configuration of the two tanks. I assume I punctured the secondary tank and the fuel gauge would not have registered the loss until the primary tank had been exhausted and the system started to use the secondary tank. If I had punctured the primary tank then I assume all fuel could potentially be lost as it drained out of the primary and then the secondary tanks. However this is a guess on my part which begs the question-
Does anyone know how they are configured-i.e. which one fills up first, whether there is one or two fuel gauges, how the measurement system works, what is the mechanism to switch over to the second tank, which tank sits higher and if you get a leak in one of the tanks how does it affect the other one?
