is there such a thing i have googled but no luck wondering if there is a app thast you can use and just plug laptop in to show if anything is stuffed TIA
program for laptop to scan 120 v6
Can you give more info amts on the hack to get OBD2 devices to work with the M-OBD protocol? I've been looking for a solution for a while but can't find a solution.Originally posted by amts View PostMy Prado is M-OBD but there is a hack to get those OBD2 devices to be compatible to the Prado's M-OBD protocol.[size=2][b]Prado 120 - 2004 GXL V6[/size][/b]
[size=1]ARB deluxe bar, OME 2" lift, Safari snorkel, BFG A/T's, Ironman winch, LED bar, Redarc DC-DC dual battery, Rhino Rack Pioneer tray, Outback drawers and plenty of goodies inside. [/size]
Cut and paste
I believe there are limitations and you don't get the full info but still better than nothing at all. Now I need to choose a suitable device off ebay. They all seem to be around the $15 mark.For those of you whose torque app cannot read the cars ecu all you need to do is create a vehicle profile for it and select automatic protocol selection then under that in the advanced settings type this:
"ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100 "
Save it and restart the app and it shall work.
Thanks. Is the Torque app available on an iPhone or PC (there are a couple of apps with a similar name)?[size=2][b]Prado 120 - 2004 GXL V6[/size][/b]
