Hi all just after some help new member i have 06 auto petrol prado was driving to day had done about 200km put the foot down a bit to over take it droped back a gear like normal but when it reaches about 3-4000RPM just losses it power(wont Go past those rpm even with more gas applied) until i let of the gas then it will change gear it has happened once before anout 6 months ago i allso have noticed befor while 4wding sometimes it will lose gears as if the gear box is overheating but the a/t light never comes on on the dash bord sorry if its not the best description bit hard to explain cheers
06 grunde auto gear box/power loss at 3-4000 RPM
Have you towed using this vehicle? How many km's have you got on the odo? Sounds like the gearbox might be failing.Originally posted by jarrad1234 View PostHi all just after some help new member i have 06 auto petrol prado was driving to day had done about 200km put the foot down a bit to over take it droped back a gear like normal but when it reaches about 3-4000RPM just losses it power(wont Go past those rpm even with more gas applied) until i let of the gas then it will change gear it has happened once before anout 6 months ago i allso have noticed befor while 4wding sometimes it will lose gears as if the gear box is overheating but the a/t light never comes on on the dash bord sorry if its not the best description bit hard to explain cheers2018 150 Series Crystal Pearl Prado VX 2.8l. 2 inch King springs and Bilstein shocks, Airtek TJM snorkel.
Hey,Originally posted by jarrad1234 View PostNar i dont tow with it its done 288000Km i was thinkin it could be the oil needs changing but ive heard u cant change oil in prado gear box
You can and should change the gear box oil. Toyota says it is a "sealed unit" that doesn't need servicing over the lifetime of the car, but don't buy it!
I change my a/t fluid after a long trip or if I've been towing for long periods, and I've done it at least 4 times in 147,000km, and I can tell you every time I've changed it, the old fluid has a very slight burnt smell to it.
If you haven't changed it and your Prado has 288,000km on it, I would get it changed asap!
Any decent mechanic can do this flush.
Make sure you get the mechanic to save the old fluid, and have a smell of it!
Good luck with it!
Best
Originally posted by jarrad1234 View PostNar i dont tow with it its done 288000Km i was thinkin it could be the oil needs changing but ive heard u cant change oil in prado gear boxLocal auto transmission specialist has quoted me $400 to do a full flush. Not sure if that good or not but its cheaper than a new box! My D4D has done 120,000 and he recommended it.Originally posted by amts View PostDefinitely needs a trans fluid flush. Then see if it improves the situation.[SIZE=2]120 GXL D4D Auto, with a 'List of Wants' greater than the 'List of Needs' greater than the 'List of Haves'
Whitey
