Cleaning Chassis Rail
  • Cleaning Chassis Rail
    Hi Guys,
    I recently purchased a second hand Toyota Prado. The car has a lot of mud build up in the chassis rail. I tried to put a hose in the holes and run water but I was unsuccessful in removing all the mud.
    Do you guys have any tips/suggestions as I would really like to clean this up.
    Any help will be very much appreciated.
    Drain cleaner attachment on a Karcher
    https://2ecffd01e1ab3e9383f0-07db7b9...18959468c9.jpg
      Sons pooey ute was the same. Just keep at it and soften the muck. You will get it eventually. We made up a 'wand' out of 1/2" copper tube and poked and pushed.
        I just took my rear bar off today to finish the rear camera install and found the same in the rear chassis rail.
        I normally get the high pressure cleaner and stick the "gun" tip into the rail and blow it all out. Works a treat, but yes my mate also have the "snake" cleaner as mentioned above and raves about it.
        [B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
          That drain cleaner looks very useful. Cheaper than my recent plumber callout fee to unblock a drain. Might invest in one. At least it has dual purpose usage.
