Adding shovel / Hi lift to Rino Pioneer Tray
  • Adding shovel / Hi lift to Rino Pioneer Tray
    Wondering if this shovel holder will fit onto the pioneer tray with the U bolts without any issues..
    http://www.ebay.com.au/itm/HD-Hi-Lif...-/291548774844
    "The bigger U bolt can hold up to 32mm diameter tube and the smaller U bolt fits up to 25mm."
    Has any one have experience with fitting ubolts onto the pioneer tray?
    Scott:?:
    Noobster
    Lurker
    Hi-lift and shovel holder
    This is how I mount mine. I prefer the quick fists over the other ways of mounting the shovel.
      Thanks for the pic.. I have the tray below with the high sides - not sure ubolts as above - a good idea now..
        If you had a set of Craig's Traxrax you could attach Quick Fists to the back of each TraxRax bracket to hold your shovel. I have seen the TraxRax mounted to this style of rack before. I have mine mounted to a Pioneer Platform but I don't have the side rails
        http://www.pradopoint.com/showthread...l=1#post505145
        Craig appears to be out of stock at the present according to the most recent post in his TraxRax thread.
