2007 Grande audio/gps unit
  • 2007 Grande audio/gps unit
    After a very flat battery,unable to use audio unit (PZQ60-00200 , 08545-00910) Have been told by local Toyota dealer that I require a "boot disk". Do not recall ever having been supplied with one.
    Can anyone enlighten me
    plaw99
    That's odd. What exactly is wrong?
      HiThere
      On start up there is a message "No map disk Inset map disk". The Load button is operative. The disk is reinserted but the message is still the same. All other buttons and knobs are inoperative. I know that there are some CD's loaded
      Thank you
        Maybe your sat nav DVD is stuffed. Try another map disk.
          I have had this happen. I think it could have been something to do with the laser in the unit not reading the disc properly.
          I tried a different disc and updated maps at the same time and it worked
          2004 Black Prado Grande
            No map disk inserted
            Originally posted by plaww99 View Post
            HiThere
            Thank you
            The part number you quoted PZQ60-00200, 08545-00910 is that for your vehicle only or is that the part for all Prados in the particular Year? I also have the same problem and was wondering if the disc may be incorrect as it tells me to check the disc as well.
            appreciate it if you could assist with this info or if any others are aware. Thanks.
