re suspension change.
  • re suspension change.
    Hi everyone, new guy to this site,just bought a 2008 gxl prado it as been used to towing a caravan it as heavy duty shocks and air bags
    fitted,feels a little firmer ride, would like to soften it up as I will not be towing with it,what shockies do you think I should put in,
    I've got medium duty Old Man Emu with airbags. Best of both worlds. Its not too hard around town and I can pump up the air bags when I need to for heavier loads eg going camping with the family
      Might be a dumb qiuestion but have you dropped the air out of the bags down to about 5psi ??
        Might help if you can tell us what shocks and springs you have.
        +1 for airbag pressure.
          Suggest you go to Toyota, and get factory shocks fitted.
            I have a set of 2nd hand factory springs+shocks (done only 40k kms) - could swap you for the rear airbags depending on what they are?
              Thanks to all of you for info have let air bags down to 7psi still a little firm,will let tjm check it out, thanks all.
