re-locking door if unopened drivers side door
  • re-locking door if unopened drivers side door
    Hey guys. When I unlock my Prado with the key beeper, if i don't open the drivers side door, after a few minutes it locks its self, regardless of whether i have opened other doors or not. quite annoying when only wanting to access the boot, or whatever.
    Is there any way of changing this so it doesn't lock?
    Thanks!
    Clancenator
    Lurker
    The other door lock switches needs some attention. Either there is a loose connection, the switch isn't fully engaging or the switch is faulty.
    Check the earth path through the bolt and body in the first instance. Then swap with a known working switch.
      Thanks amts. Now i think about it, my boot switch isn't working properly, as the light isn't coming on when I open the boot. I will have a look at that, cheers
        From memory the rear door does not trigger the computer to stop the vehicle from relocating after a timeout. Be careful not to put your keys in the back if you haven't opened another door.
          Mine will not relock if I open the rear door.
            Will re-check mine when its gets home.
