Scangauge, Techstream, OBD2 reader, Torque Pro, Autel or something else?
  • Scangauge, Techstream, OBD2 reader, Torque Pro, Autel or something else?
    Hi all,
    So after reading many threads so far, I am trying to find a solution to monitor the D4D Auto 120. At this point I am looking towards the Scan gauge and also buying an Autel Scanner.
    While travelling
    Monitor Trans Temp
    Engine Temp
    Will probably get a Exhaust temp bung welded into the Exhaust to monitor that
    Boost
    When at home
    Error Codes (and reset)
    Injector Values
    We are a iOS family, though could buy a android device to run Torque Pro if it has advantages. The Headunit in the car is not running on android either.
    Cheers.
    [B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
    I am IOS inclined found EOBD-Facile to be ok for a free app, further down the road will be getting a Android Head-unit for Torque Pro though. Had to buy a wifi OBD2 which I got off ebay works. But I have a V6 and am monitoring Maf/Fuel trims etc for later adjustment.
      I have the Ultraguage unit via their Bluetooth OBD dongle running on a car mounted iPad mini. The app is really powerful where you can make up your own custom gauge display and even use the scangauge codes to extract the trans temps. Works well.
