auto gear
  • auto gear
    hi
    when im changing from D TO 4
    (moving top the side )
    its bit hard and i hear knac .
    is that normal ?
    all other gear changing are smooth
    No, not normal. You'll need the shift lever repair kit. The pin is about to pop out.
      is it big problem to fix ?
      thanks
        No, not a big problem.
        http://www.pradopoint.com.au/showthr...ver-repair-kit
          thank you so much ,
            if you dont mind one more thing
            i head to change the rear main seal
            the mechanic broke one bolt ,he saying it was rusty its broken inside .
            he change the main seal, now i am missing one bolt ( as photo attach )
            what do you think is it OKClick image for larger version
Name:	prado rear main.jpg
ID:	656254 to drive like that , he say there is nothing to do
            thanks
              Your mechanic broke a bolt and gave the car back to you..? That's lazy.
              Broken bolts can be drilled and removed with an easy-out. There's mobile services that will do this for you for a fee if you have no luck with your mechanic. The car would be ok to drive as there are other bolts holding the gearbox on. Long term however if you plan to go offroad or tow a van it would be best to fix. The manufacturer designed the car with that bolt for a reason.
                I would be finding a new mechanic...
                [B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
