Fuel sensor issue
  • Fuel sensor issue
    Hi all. 2 queries. First is simple: when you fill your tanks to the brim does the needle hit the F or just a bees dick below it?
    2nd is a real issue. The fuel light came on and showed E however the day b4 it was used it was just under 1/2 left. I went and filled it up and only got 128 ltrs in so I'm 50 odd liters short.
    Does this sound like a fuel sensor/sender unit fault in the middle tank?
    Is it hard to change?
    When filled to full, the needle is over the F.
    For the 2nd issue, sometimes my needle varies and doesn't actually correspond to the actual fuel level. There is something wrong with the fuel sender "sticking". I just go by the tripmeter reading. My issue is intermittent. At one stage, the needle was swinging "wildly" between trips. The distance to empty varied by about 200km between one trip to the other. The issue kinda fixed itself for a while but then came back but the needle swinging is less noticeable.
      Mines weird too. When it's on second tank (90l light on), and I drive for awhile, say it reads half on the gauge. Then I stop and go shopping or work etc and then get back in and start it, it reads near 3/4 tank but drops (eventually) to its "true" level. Some mornings the low fuel light comes on even though it read 1/4 of a tank the night before it takes about 12-15klms of driving for it to come back the the 1/4 mark. Strange but I'm getting to know it.
