replacing engine cover bolt
  • replacing engine cover bolt
    Noticed the last time my car was serviced the 2 bolts securing the engine cover have been overtightened and has a result one of the nuts on top or the cover will not come off, it just turns and turns, Therefore I had to slighty damage the right hand side cover where it fits over the nut to remove the cover, then I noticed the bolt and nut just turns and where it is fitted some mechanic has tried to vice grip the bolt and remove the nut, and it did not work.
    My question is has any one ever replaced this bolt and how is a new one fitted?
    2005 V6 Grande, Sovereign Bull Bar, Piranha Dual Battery System with dash monitor, GME TX 3440 CB, Impco Gas conversion, Tmax Winch with Plasma rope, Outback ideas recovery points, ATS suspension upgrade.Sandgrabba mats. Milford Cargo barrier.Rhino roof rails.
    Re: replacing engine cover bolt
    Never replaced one, but short answer, take it back and get them to fix it. Below standard behaviour. :twisted:
      I wish it was that easy
      work done in Melbourne
      and I'm in Broome!
      thanks anyway
      Cheers Stevo
