Fog Lights in South Australia illegal to use
  • Fog Lights in South Australia illegal to use
    I have a Prado GXL 08 model with the Sovereign bull bar with the standard foglights fited. I use them on the open outback roads with parking light only on so that we are more visible during the day.
    Well I have just been pulled over and given a caution because they are illegal to use in SA unless they are used in adverse weather. I had no idea. They are pointed down so they are not blinding, but aparently the amnesty (had no idea there was one) is over and the police are supposed to fine offenders from now on. The copper was quite nice about it and only cautioned me as he also doesn't believe there was enough consultation.
    I believe that the law also came into effect recently in other states.
    [size=7][color=#0000BF]Late 2008 GXL D4D 6sp man, white, Sovereign bull bar, 2.5t tow bar, Head light protectors, Bonnet protector, Cargo mat, Front side window weathershields, Roof rack & bars, Dual bateries[/color][/size]
    Re: Fog Lights in South Australia illegal to use
    its being the law in NSW for a while now. One of my friends copped a fine for this around 2000-01.
    2000 Toyota Prado GXL- Gone, but not forgotten...
    '92 Landcruiser HDJ80 4"lift 33's
    '91 Surf LN130 coil sas, 4.8s, 35s
    '12 Jayco Eagle Outback
      I remember there being an article about this in the paper here in SA some time ago. I noted whenit was written, that they referred to "fog" lights. I always refer to mine as "driving" lights, and I have remembered seeing in a toyota catalogue that is what they classified them as....
      This could be a technicality to get out of a fine.....
        Except that I don't think you are allowed to use them either.
        In any event, the law is stating the obvious. This is as it should be. As usual, the idiots force the hand of the authorities so things have to be set in stone.
        Be good if they could fix the ADR's while they are at it so the fog lights won't come on with the normal high/low beams at the same time. Too many cheap Korean cars driving around with everything blazing. :roll:
          I just checked toyota website and unfortunatelly they are calling it fog lights. That means that here in the desert they are totally useless to me.
          http://www.toyota.com.au/prado/features/exterior
          Fog lights
          In foggy conditions, conventional headlights only make matters worse because their light is simply reflected back into your eyes, further obscuring your vision. Prado lights the way with fog lights mounted within the bumper (on GXL, VX & Grande), so you can safely and easily navigate through early mornings and high passes.
            I believe this has been law for ages. It's being enforced now due to rice boys driving around with 100W fog lights.
              ........and the tools in Crappadores and Falcoons which have the worst 'fog' lights for annoying the hell out of any other road user!
              June 2008 Prado GXL D4D Auto with Option Pack1, ATZ Mickey Thompsons, Indash Digioptions DVD/CD/SatNav. running OziExplorerCE, Reverse Camera, IC7000 Icom VHF/UHF/HF, Codan 9350 Autotune, Uniden UHF CB, ARB Color Coded Steel Winchbar,X9 Superwinch, Hella Rallye 4000 HID's, King Springs 2 Inch Lift, Milford Barrier, Redarc Dual Battery System, Drawers and Waeco Fridge...........and August 1979 Landcruiser FJ40 Shorty, B.F. Goodrich ATZ, ARB Steel Winchbar, Heaters, Wipers, Headlights!!!
                The front fog lamps never bother me because they are aimed low to the ground. But it's the retina burning bright red rear fog lamps that really irritate me. :evil:
                  In QLD, there is no specific rule against front foglghts, it says in the Regulations
                  219 Lights not to be used to dazzle other road users
                  A driver must not use, or allow to be used, any light fitted to or in the driver’s vehicle to dazzle, or in a way that is likely
                  to dazzle, another road user.
                  Maximum penalty—20 penalty units.
                  There is however a rule for rear fog lights
                  217 Using rear fog lights
                  (1) The driver of a vehicle fitted with a rear fog light must not operate the fog light unless the driver is driving in fog or
                  other hazardous weather conditions causing reduced visibility.
                  (2) In this section—
                  rear fog light means a light fitted to a vehicle to make it more easily visible from the rear in fog.
                  I agree with the previous post about some of the Jap Imports, Commodores and Falcons, a lot of then drive around with then all day with very bright, poorly aligned fog lights, making it very annoying for oncoming traffic.
                  Personally, I use mine occasionally in really dark areas (say on the road out to Samford), as the Prado lights are normally so feeble. But that's about it. I think I have seen fog once in 17 years of living in Brisbane, so for the most part they are pointless,
                  Neil - Porsche 911 (997.2 2009) Carrera S
                    I came across this Post on ExploreOz forum about changes to the road rules for all states and territories from January 25 this year. About the fog lights it states:
                    Fog lights
                    Drivers can only use front fog lights in hazardous weather conditions. This brings the rule into line with the existing situation for rear fog lights. Use of fog lights in other conditions can dazzle oncoming drivers. Previously front fog lights that dazzled approaching drivers were dealt with as an offence under a different rule.
                    Penalty $140
                    White 2008 Prado GX D4D Auto w/ Option Pack 2 + a few additions...
                      Of the topic but still to do with new penalties.....
                      Just caught a story on the radio. In SA, red light/speed cameras will now be used to check vehicle registrations and the fines are going up.
                      No redgo $2500 fine.
                      No compulsory 3rd party bodly injury insurance $5000 fine.
                      Mick
                        More revenue for the moneyless governments :roll:
                        Unless SA has got some new fibre networks or pumped up NextG, I would call this one creative journalism. The down/up load requirements are currently restricting live rego/insurance cameras - the datasets are massive and dynamic i.e. it needs refreshing almost every minute.
                        What is interesting and wilby in most hwy patrol cars in the not to distant future is a fully mobile, vehicle based - speed, rego/insurance camera
                        "Ooops I just deleted the internet, lucky I was able to recover 99.7% of it out of the bin" :lol:
                          Not so sure about that. About 2-3 years ago I did contract work on the goverment "Truck Scan" network. This system also reads plates but mainly to catch out truckies falsifying their log books, so the technology is certainly not new, it's in use and it works.
                          Anyway found this on from AAP:
                          AAP, May 3, 2009
                          Road traffic cameras in South Australia will from June not only catch offending drivers but also unregistered and uninsured vehicles.
                          Road safety minister Michael O'Brien said all cameras, including speed and red light cameras could now be used to detect illegal vehicles on SA roads.
                          Previously police have not had the powers to match licence plates with registration details.
                          Mr O'Brien said the increased detection capability would be complemented by tougher penalties for owners who failed to register their vehicles and take out compulsory third party insurance.
                          "The maximum fine for failing to register a vehicle will jump from $750 to $2500, while failure to insure will attract a maximum fine of $5000, up from $2500," he said in a statement on Sunday.
                          "We're acting to reduce the number of unregistered and uninsured vehicles on our roads, which research suggests has risen by around 30 per cent in recent years."
                          A one-month public information campaign commences on Sunday, with the changes to come into effect from June 1.
                          Mick
                            why not just forget about the foglights and use the auto on/off function of your low beams?
                            [size=2][color=#00BF40][b]2003 120 GXL V6 auto[/b]. GME TX3440 and AE4703, Mickey Thompson ATZ 4 rib LT265/70R17 plus roadies, Ausguard cargo barrier, BD bash plate, OME lift with Sport shocks. And hopefully more to come, slowly slowly...[/color][/size]
                              Same thing happened to me in WA..
                              But i got off with a caution too and pleaded ignorance to the rules.
                              (funny thing was i only had my parking lights on - but they are on the soverign bar too and were mistaken for dim fog lights...)
                              2004 Black Prado Grande
