Reversing Work Lights
  • Reversing Work Lights
    I'd like to fit a reverse/work light set up to the rear wheel carrier of my Prado, but can't find a telescopic kit apart from Kaymar, (That only works on their bumper without modifications) - any ideas/examples?
    04 Prado Grande
    Mag Light
    Fire Extinguisher
    Bushranger Recovery Gear
    Parrot Bluetooth
    Bootliner
    IPF Spots
    ARB Recovery Points
    Toyota Alloy Bullbar
    Dual Batteries
    Safari Snorkel
    Rhino Rack
    Toyota Tow Bar
    Side Steps
    Waeco 50l Fridge
    Cargo Barrier
    Engine mounted ARB Compressor
    GME TX4400
    Coopers ATS
    Reversing Camera
    Bonnet and Light Protectors
    Rear in-seat DVD & Playstation
    Grill Fly Screen
    Re: Reversing Work Lights
    This is Kaymar
      G'day,
      I have a 100w Hella worklight mounted to my rear roof rack bar. I made the bracket to bolt under the roof rack, to get it as low as possible, and I leave the light in the horizontal position until I need to use it. Never had any problems with height, as it is only just heigher than the roof rack bar. It's also less tempting to the light finger brigade.
      Regards,
      Bazza.
        hey D4D how high does the work light extend on the kaymar rear wheel spacer???
        and is the spacer heavy??
        thanks
        06 GXL 3.0LT TURBO,50 mm ride pro lift, poly bags,arb roof rack with 4x ipf 800xs driving lights,arb awning,gme radio,red arch dual battery with pirhana batt monitor,2x ipf 800xs driving lights on soverign bar,mickey thompson ATZ, kaymar rear wheel spacer,tinted windows,red arch electric brake controller,diffx2 transfer case and gear box breathers just fitted front and rear recovery points.
          See also viewtopic.php?f=16&t=8201 - I have almost finished mine; just getting the AUX Battery installed on Wednesday.
          I've used the Kaymar bracket and it works beautifully...I painted the upright black, a bit of a wank, but it looks better. I ahve also replaced the light with a Narva dual beam work light.
          Neil
          Neil - Porsche 911 (997.2 2009) Carrera S
            I believe the Kaymar work light can be raised approx 18" above where it normally resides.
            A question though - where are you running your wiring for your light? I have heard some people are drilling a hole through the centre of one of the bolts that hold the Kaymar bracket onto the door. Interesting thought, but I have never seen this done yet.
            What are the alternatives for running the wires for powering the work light besides drilling a hole into the back door and running the wiring through a grommet?
            SSSHHHH be very very quiet were huntin wabbits.
              I just drilled a hole in the back door, used a gromet and soem gasket goo. I guess the other option is running it around the door somehow.
