Towing using Toyota hitch receiver
  • Towing using Toyota hitch receiver
    Hey all, I'm thinking about getting a caravan sometime soon to tow with our 2008 VX diesel Prado. Van will probably be about the 21' lenght and well within the 2500kg/250kg ball weight rating.
    Should I be using a weight distribution hitch? If so will this work ok with the Toyota hitch or will I be needing to ugrade to a hayman reese hitch receiver?
    Would I be better of with higher rated springs all around?
    What is the general feeling out there as I have read about the Toyota hitch receiver failing on some occassions when using a WDH?
    Not of this Earth
    Somewhere in my 2010 200 Series Landcruiser Sahara
    slowly being improved for the real world
    2013 Jayco 21.65-4 Sterling Outback with twin slideouts and simplicity suspension
    Re: Towing using Toyota hitch receiver
    Do not use a WDH with Toyota towbar.
    All reports of 120 Prado towbars failing have been when a WDH has been used.
    Using a WDH with a Toyota twobar will void warranty.
    If you must use a WDH get a HR towbar.
    Leachy
    EX-Prado Owner
      Ok, thats pretty much what I'm starting to think too! Althought the Toyota handbook on page 256 does say "Whem towing a caravan trailer etc., use a distributing hitch" and my local toyota dealer has said it shouldn't void the warranty. For piece of mind etc I think I might have to go for a Hayman reese hitch too.
      Or would I be better off with stiffer springs instead of a WDH if it does sag in the back end when hitched?
      Not of this Earth
        x2
          Were you referring to this thread?
          Toyota Towbar Failure
            Yup, thats the one among others I have read. Pretty scary stuff!!!
            Not of this Earth
              I went with medium rated springs and polyairs, so far so good. If you go heavy duty in the rear, when not towing it's not a good ride unless you have a few bags of cement in the back.
